2004 Ford Taurus Transmission slipping
BMACCH
  • 2004 FORD TAURUS
  • 6 CYL
  • 70,000 MILES
I had the transmission fluid and filter changed,
now the trans slips when comming out of a turn
and excelerating.
Thursday, January 29th, 2009 AT 2:02 PM
JGAROFALO
  • 489 POSTS
Start by checking the oil level. This is done with the transmission warmed up to operating temperature with the engine idling in PARK or NEUTRAL. If the oil ilevel is OK, then either the filter is not properly seated or possibly the wrong filter.
Saturday, January 31st, 2009 AT 6:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation.
Did you have transmission flushed completely at a shop or did you just have fluid and filter replaced?
Perform test procedures as stated by jgarofalo and post results, I will follow up.
Thanks for using 2CarPros. Com!
Friday, February 6th, 2009 AT 7:37 PM
BMACCH
  • 8 POSTS
I had the trans flushed and fluid and filter chaged.
Saturday, February 7th, 2009 AT 1:19 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Okay. Was this the first flush of the vehicle's transmission since owned? If so, flushing it has probably stirred up the dirt on the bottom of the transmission and has now contaminated the "new" transmission fluid. I suggest having the fluid and filter changed, not flushed, and it should be running smoothly again.
Saturday, February 7th, 2009 AT 6:31 PM
BMACCH
  • 8 POSTS
I added 1 quart of motorcraft micron V trans fluid,
the slipping has stopped, should I do anything else?
Sunday, February 8th, 2009 AT 6:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If slipping has stopped then it was just low. You should be okay until time for another tranny fluid change.
Sunday, February 8th, 2009 AT 6:44 PM
