The problem with your blower is not only the motor, but the blower relay. It is located in the heater box close to the blower motor. However, the TRUE cause of this problem is a water leak. The problem is the wiper arm cowel at the base of the windshield. They warp and allow water intrusion into the fresh air filter intake. The water runs down and corrodes the relay and the motor. To resolve the concern Ford came out with an entire procedure that calls for the replacement of the cowel, relay and motor, as well as the modification of the air intake box. Check with your local dealer to get all the updated parts. Simply replacing the motor and relay won't be a long term solution to the problem.
Saturday, January 5th, 2008 AT 8:34 PM
