2003 Ford Taurus
AIMEEE667
  • 2003 FORD TAURUS
  • 6 CYL
  • FWD
  • 200,000 MILES
It was -35 for 3 days, the car was running great, warmed up -15. The car stalled when driving no sputter just died, when started on 2 try there was a ticking noise that never went away. Done same thing 4 more times over 24 hrs, then it started to screach, by the time I got it home the moter was making load noises then engine light came on. Can you pls. Help. Low income no money and it is xmas
Wednesday, December 16th, 2009 AT 9:15 PM
  • 31,937 POSTS
Hi there, the first thing you need to do is go get a scan done as I will need the set fault codes set in the ECU, this is what is indicated by the check light, start here.
Mark (mhpautos)
Wednesday, December 16th, 2009 AT 9:18 PM
