2003 Ford Taurus
TODDBINDER
  • 2003 FORD TAURUS
  • 6 CYL
  • 60,000 MILES
What needs to be serviced on a car w/60k miles on it, what really needs to be done and what is not pressing to be done?
Friday, January 9th, 2009 AT 8:05 PM
BMRFIXIT
  • 19,053 POSTS
2001 Ford Taurus LX
Page 1 of 1
 Severe Maintenance Labor Hours Â
 APPLICATIONLABOR TIME
O.H.C.- DOHC 4.9 O.H.V. 4.2
 Severe Maintenance Details Â
Add Detail Lines as Notes Please Note: Maintenance detail items may include multiple vehicle configurations. Therefore, it may be necessary to edit the detail items on the worksheet. 60,000 Miles (96,000 Kilometers) : All Applicable Models
OPERATIONCOMPONENT
INSPECT BALL JOINTS If equipped.
INSPECT BRAKE SYSTEM Inspect brake pads, shoes, rotors, drums, brake lines & hoses. Inspect, replace or lubricate under the following conditions: Extensive idling and/or low-speed driving for long distances as in heavy commercial use such as delivery, taxi and patrol car.
INSPECT ENGINE COOLING SYSTEM HOSES & CLAMPS
INSPECT EXHAUST SYSTEM & HEAT SHIELDS
INSPECT PARKING BRAKE SYSTEM
INSPECT STEERING LINKAGE
INSPECT SUSPENSION COMPONENTS
LUBRICATE BALL JOINTS If equipped with zerk fittings. Inspect, replace or lubricate under the following conditions: Extensive idling and/or low-speed driving for long distances as in heavy commercial use such as delivery, taxi and patrol car.
REPLACE AIR CLEANER/ELEMENT Replace more often under dusty conditions.
REPLACE AUTOMATIC TRANSAXLE FLUID
REPLACE CABIN AIR FILTER If equipped. Replace more often under severe driving conditions.
REPLACE ENGINE OIL
REPLACE ENGINE OIL FILTER
REPLACE FUEL FILTER In Line Fuel Filter Replace it under any of the following conditions: Extensive idling and/or low-speed driving for long distances as in heavy commercial use such as delivery, taxi, patrol car and in dusty conditions such as as unpaved or dusty roads.
REPLACE SPARK PLUGS Inspect, replace or lubricate under the following conditions: Extensive idling and/or low-speed driving for long distances as in heavy commercial use such as delivery, taxi and patrol car.
ROTATE TIRES
Friday, January 9th, 2009 AT 8:11 PM
Related General Content
