2003 Ford Taurus
FELICIA
  • 2003 FORD TAURUS
  • 6 CYL
  • 4WD
  • 67,000 MILES
My brake warning lamp comes on but never stays on it just stays on for a few seconds and then goes off
Thursday, December 4th, 2008 AT 4:03 PM
ZACKMAN
  • 4,202 POSTS
You are low on brake fluid. 2 things to do. Make sure that you don't have any leaks in the brake hydraulics. If there is no leak, pull front tires and check you brake pads. They may be thinning enough to lower the level of the brake fluid in the reservoir, thus setting the low level sensor light.
Thursday, December 4th, 2008 AT 10:04 PM
