2002 Ford Taurus help
AANDREWS23
  • 2002 FORD TAURUS
  • 6 CYL
  • 88,000 MILES
I'm located in germany and have a 2002 ford taurus se and there is a burning smell by the belts what could be the problem and how do I fix it
Friday, January 16th, 2009 AT 5:38 AM
DAVE H
  • 13,383 POSTS
BELT ADJUSTMENT
Check belt for fraying. If fraying exists, ensure belt and tensioner are properly aligned. Automatic tensioners are calibrated to provide correct amount of tension to belt for an accessory drive system. Unless a spring within tensioner assembly breaks, or some other mechanical part of tensioner fails, there is no need to check tensioner for correct tension. Continental and Escort models have tensioner belt wear indicators. Tension is within specification if tensioner pointer is within indicator markings. If tensioner reaches travel limit, as indicated by marks on tensioner, replace belt. Ensure serpentine belts are properly installed.
Friday, January 16th, 2009 AT 5:42 AM
Related General Content
