2002 Ford Taurus dash lights
CARDAD
  • 2002 FORD TAURUS
  • 6 CYL
  • FWD
  • 89,000 MILES
How do you replace the dash light that illuminates the odometer?
Sunday, November 22nd, 2009 AT 7:24 AM
BMRFIXIT
  • 19,053 POSTS
Lights located at the rear of the cluster
cluster panel need to be removed to enable bulb replacement
Tuesday, August 6th, 2019 AT 5:11 PM
CARDAD
Does the cluster panel remove from the back, or front of the panel?
BMRFIXIT
  • 19,053 POSTS
INSTRUMENT CLUSTER
Removal & Installation (Floor Shift)
Disconnect negative battery cable. Tilt steering column to lowest position. Remove instrument cluster finish panel. Remove instrument cluster retaining screws. Pull top part of instrument cluster toward steering wheel. Disconnect instrument cluster harness connectors. Remove instrument cluster. To install, reverse removal procedure.
Removal & Installation (Column Shift)
CAUTION:DO NOT use excessive force when installing radio remover. Excessive force will damage retaining clips and make control panel removal difficult.
Disconnect negative battery cable. Tilt steering column to lowest position. Remove upper and lower steering column covers. Remove instrument cluster finish panel. Push in Radio Remover (T87P-19061-A) into integrated control panel face plate about 1.5" (38.1 mm) to release retaining clips. Disconnect integrated control panel harness connectors and remove integrated control panel.
Remove instrument cluster retaining screws. Disconnect transmission range indicator cable from column selector tube. Pull top part of instrument cluster toward steering wheel. Disconnect instrument cluster harness connectors. Remove instrument cluster. To install, reverse removal procedure.
