Is your car running hot? If yes then I would be concerned with the radiator or the thermostat. If it's not running hot and you don't have heat, flushing the radiator means squat. The heater core could be partially clogged or the a/c electronic blend door actuator may be operating incorrectly, or not at all. I would recommend you get some type of repair manual, Chiltons maybe, something that has the heating/cooling system repair in it. Did you directly flush the heater core as I suggested? You may have to jury-rig the flushing hose and drain hoses, not hard to do. If you have not done this yet, it's what I would do next
Friday, November 10th, 2017 AT 12:28 PM
