2001 Ford Taurus Transmission
2001 FORD TAURUS
93,100 MILES • 6 CYL • FWD • AUTOMATIC
KCLONGORIA
My car is a 2001 Ford Taurus v6 3.0 single cam with 93100 miles on it. My problem is that when I'm at a stop it vibrates or misses. I kinda feel like when a plug or wire is not good. I already changed the spark plugs, wires, EGR valve, pressure sensor, and now the coil. Nothing makes a difference. Once I'm at normal speed 10mph and up it runs fine. Now it developed another problem. The light on the dashboard is on, the one that's a gear with an exclamation point inside it. I think it's the one for the transmission. Again when I'm at a stop and speed up it takes a while to gain speed like low power. I took it to AutoZone to get checked and it came back with a solenoid problem. I decided to check the fuses under the hood and the #28 fuse which has someting to to with the solenoid was blown. What's causing this?
Dec 29, 2007 at 11:50 PM
MERLIN2021
  • 17,250 POSTS
If you could post the code that autozone read with the scanner, this will help us determine the best course of action for you.
Dec 30, 2007 at 12:18 AM
