2001 Ford Taurus SES 102,000 miles
MANO2K1
  • 2001 FORD TAURUS
The car drives fine, but when you are parked or when the car has come to a complete stop it seems to idle low and want to shut off. Maybe like not getting enough gas or air? Someone said try cleaning the carburator or the idle air control?
Tuesday, September 25th, 2007 AT 1:14 PM
SERVICE WRITER
  • 9,123 POSTS
Ceaning the idle control valve sounds like a good spot to start, follwed by the egr valve and then throttle bore and intake valves, (no carburetor on this one)
Tuesday, September 25th, 2007 AT 3:06 PM
MANO2K1
  • 5 POSTS
Just to let you know I am not mechanically inclined, I am a Net Admin, learning to do this. Is there a good place on the web to get pics or should I just buy a Haynes manual or Chilton. Also is one better than the other?
Tuesday, September 25th, 2007 AT 3:14 PM
SERVICE WRITER
  • 9,123 POSTS
Note:on fords do not use throttle cleaner. a little rubbing alcohol and a rag to wipe it.
https://www.2carpros.com/topics/egr.htm
https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://www.2carpros.com/forum/automotive_pictures/30961_seafoam_3.jpg
For the intake valves, follow the directions regarding tha part about putting it into the vacuum line....save this for last and we can go through it.
Tuesday, September 25th, 2007 AT 6:45 PM
MANO2K1
  • 5 POSTS
Turns out the PCV elbow that connects the valve has a hole and is kind of in bad shape. I have taped it up for the time being and I am searching for one.
All of the auto shops can't get it and say I have to go through the dealer. So we will find out tomorrow. Hopefully they have it in stock.
Thank you for your help.
Thursday, October 4th, 2007 AT 7:53 PM
