2000 Ford Taurus Power Steering Whine
SKI-DOO-RULES
hi, i have a 2000 ford taurus 3.0l the power steering is making a very bad "whinning" sound and the fluid was black. so i replaced the pump, flushed and burped the system of air and still had the same whinning sound. replaced the rack, reflushed and burped the system of air, and still have it. i'll have the car running and the fluid at the proper level, then shut the car off the fluid comes flooding up outta the pump???? help! does it have anything to do with that "bulb" shaped deal on the steel line that feeds the rack????? any answers would be greatly appreciated.
Apr 21, 2007 at 2:39 AM
2CARPRO JACK
  • 11,533 POSTS
Enjoy your Ford p/s...LOL Did you use a factory pump? that is the best shot you have at it being quiet. Most aftermarket pumps come with a tag saying to give it a 500 mile break in. Need to adjust the fluid level with the engine off.
Apr 22, 2007 at 1:23 AM
Suggested Repair
Use a factory power steering pump for the best chance of quiet operation. Aftermarket pumps often need about a 500-mile break-in. Set the fluid level with the engine off.
Conversation Summary
The owner of a 2000 Ford Taurus 3.0L reported a loud power steering whine and black fluid. Replacing the pump and rack and flushing and bleeding the system did not stop the noise, and fluid surged out of the pump when the engine was shut off. The expert said a factory pump is the best chance of quiet operation, aftermarket pumps may need a 500-mile break-in, and the fluid level should be adjusted with the engine off.
