Engine stalls at idle early in the morning when the engine is cold
10,000 MILES • 6 CYL • FWD • AUTOMATIC
LTRIB
Engine stalls at idle early in the morning when the engine is cold. I have to hold my left foot on the accelerator pedal at traffic lights, stop signs, etc. Once the car is warmed up, the engine will rarely stall. Had the engine looked at and was told there might be a vacuum leak .... where is unknown. What are the possible causes? Thanks!
Feb 6, 2009 at 6:29 AM
SQM
  • 6,383 POSTS
Vacuum leak can lead to the engine stalling when cold. Typically, with vacuum leak the engine will also run rough.
A vacuum leak can be from any of the vacuum hoses under the hood. It can also be from a leaking intake gasket. It is possible that the intake gasket leaks only when the engine is cold as it warms up everything expands and seals the leak.
You can check for vacuum leak at the intake gasket by spraying carburetor cleaner, while the engine it at idle, at the base where the gasket is. If there is a leak the engine will react to the carburetor cleaner and will idle height for a little bit, then go back down after the chemical burns off.
Here is a helpful guide:
Dec 9, 2021 at 12:52 PM
