1999 Ford Taurus SE Serpentine Noise
Suggested Repair
Replace the serpentine belt tensioner and remaining tensioning pulleys. A similar Taurus noise was resolved by replacing all tensioning pulleys. Do not use WD-40 on the belt; use a proper belt lubricant if needed.
Conversation Summary
The owner of a 1999 Ford Taurus SE reports a serpentine-area noise like a failed water-pump bearing. The water pump, idler pulley, and alternator were already replaced. Spraying WD-40 on the water-pump pulley quieted the noise only briefly, and it returned after the water-pump replacement. The owner is considering a new spring-loaded belt tensioner. Expert replies indicate a pulley is the cause and that replacing all tensioning pulleys fixed the same issue on another Taurus. They also advise against WD-40 because it can damage belts and suggest belt lubricant instead.
