1999 Ford Taurus Harmonic Balancer bolt
1999 FORD TAURUS
BROADSTREET24
Engine Performance problem
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic
My car sheared the crankshaft damper bolt and to fix it, I need to replace the harmonic balancer bolt. I have yet been able to bust it loose. I been using a 3/4 inch impact, but it hasn't come loose yet. Are there any other options that I can try?
Aug 11, 2009 at 12:38 PM
BMRFIXIT
  • 19,053 POSTS
The threads on the crank pulley are left handed
Aug 11, 2009 at 2:00 PM
BROADSTREET24
The crank pulley is already removed. The bolt that holds the harmonic balancer on has a stud on it that is left hand thread for the pulley nut, but the actual bolt into the harmonic balancer is right hand thread, right?
Aug 11, 2009 at 2:38 PM
