My Taurus runs good. I know that it needs to have the front left wheel hub barrens changed. The major problem is that when I drive the car for a hour or more it will just cut off. If I wait for a hour or so it will start back up with not problem. The car does not over heat. When the car shuts off, there is a burning smell in the air. The check engine light is not on. I have changed the fuel filter on the car.
SPONSORED LINKS
Wednesday, August 12th, 2009 AT 8:18 PM
DOCFIXIT
MECHANIC
Need to determine if ignition or fuel is problem. When it stalls spray carb cleaner into intake crank does it fire up? If yes then fuel is problem. If no then ignition is problem.'
Let me know
Thanks for donate
SPONSORED LINKS
Thursday, August 13th, 2009 AT 8:31 AM
KEMCAN2
MEMBER
Yes, I have sprayed carb cleaner in it. It did not crank up. When you say iginition, do you mean the distributor, or spark plugs?
Thursday, August 13th, 2009 AT 1:09 PM
DOCFIXIT
MECHANIC
Don't have distributor and plugs maybe one but not all six. More likely crankshaft sensor but that should set code. Coil maybe? It may come down to PCM you say no engine light have you hooked up scanner? If not that may point to some fault.
