1998 Ford Taurus door ajar
BP1960
  • 1998 FORD TAURUS
Electrical problem
1998 Ford Taurus 6 cyl Two Wheel Drive Automatic 106k miles
The door ajar and dome lights are constantly on, even with all 4 doors shut.
Saturday, April 3rd, 2010 AT 11:19 AM
JUSTDON
  • 150 POSTS
Typical Taurus problem. Use some WD40 and spray it in the door latch. Open and close the door several times. Spray more WD40 in it every 5 or so door closes. If the light still stays on, move on to the next door. Start at the drivers door. When you find the right door causing the problem, go ahead and do the same to the rest of the doors. You may have to open and close the door(s) many-many times to get the light out. But, it will go out.
Tuesday, April 20th, 2010 AT 10:04 PM
