1998 Ford Taurus
WALLDOG
  • 1998 FORD TAURUS
  • 6 CYL
  • 121,000 MILES
The car cranks fine and run at park and neutral like is new but as soon as you put it gear the car stalls out. Put a different mass flow sensor in and still problem. Going to try tps sensor next then the IAC valve then the range sensor unless you have a better possibilty.
Wednesday, November 26th, 2008 AT 6:30 AM
RENAUDTN
  • 636 POSTS
You probably have either the AXOD, AXOD-E or AX4S Ford transmission in your car; ford has had a lot of problem with those.
Start by checking for codes; it may help to pinpoint your problem.
Have you checked your ATF?
You probably need to have a Ford transmission tester connected to your car to troubleshoot your transmission.
You could have a problem with your shift solenoids, OSS Sensor, TCC solenoid, TSS sensor, bad pump bearing. This are just a small list of what may be causing your problem.
Don't waste your money shotgunning parts. Save it to have your car diagnosed at a ford dealer.
If you have a scanner that can read sensors input, check that.
Unless you find a DTC with a scanner to put you in the right direction, I would take it to a dealer to have it inspected.
Wednesday, November 26th, 2008 AT 12:39 PM
WALLDOG
Thanks renaud I think i'll take the advice and let the dealer dianose the problem then I'll fix it.
Wednesday, November 26th, 2008 AT 4:46 PM
