1995 Ford Taurus Car Stalls
NLIZOTTE
Engine Cooling problem
1995 Ford Taurus 6 cyl Two Wheel Drive Automatic
I have a 95 Ford Tarus and when the car gets hot it stalls. When it is cool outside the car runs, but is sluggish. What could this be? Mass Air Flow Sensor and Oxygen Module?
Jun 22, 2009 at 1:43 AM
  • 110,248 POSTS
Does the car restart? Has the check engine light come on? Have you checked fuel pump pressure?
Jun 22, 2009 at 2:06 PM
NLIZOTTE
Yes the car will restart after cooling down. The check engine light has not come on. We let the car sit for 4-5 hours on Saturday and than was able to drive it back home after it cooled off. No don't know how to check the fuel pressure.
Jun 22, 2009 at 11:13 PM
  • 110,248 POSTS
When the engine won't start, there will be on of two things missing in this case, fuel or spark. Here are the how to's for checking both. Remember, do this when it doesn't start.
Let me know what you find.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
Jun 23, 2009 at 7:13 AM
