1993 V6 3.0L 122K miles stalls, bucks hesitates
PCGENIUS
  • 1993 FORD TAURUS
I have a 93 taurus w/ 122k original miles. I drove it down the e. Coast and it got 30MPG and ran like a champ. Now it has problems where it hesitates alot, bucks like a denver Bronco and usually dies. It always starts up again, though. The check engine light comes on about once every 10 days, stays on for about 1/2 mile and then goes out. I almost suspect a vac leak as it started out being a little hesitation at first and now I'm almost afraid to drive it. I took it to Pepboys who said to take it to a ford dealer and put it on a breakout box. I'm kind of afraid of what that'll cost. They also told me that I would just be throwing parts at it til I get the right one. Any help on this would be greatly appreciated. Thanks
Wednesday, November 14th, 2007 AT 1:54 PM
TAURUSWHEEL
  • 718 POSTS
Find a local autoparts store that will read your pcm for stored codes, i'm surprised Pepboys didn't do it.A breakout box is not needed unless so-called pinpoint tests are run, which are not until whatever issue is indicated by the check light, is attempted to be resolved. In a lot of instances, it is still not needed. If you get, say a code for the egr pressure sensor, makes more sense just to initially replace the sensor then paying a qualified repair shop to diagnose further, if new part doesn't solve the issue, then further testing is certainly warranted. The advice about not wasting $$$ on uncertain part replacement is very good though
Wednesday, November 14th, 2007 AT 6:32 PM
