1992 Ford Taurus
WOLSTRIDER
  • 1992 FORD TAURUS
  • 6 CYL
  • FWD
  • 90,000 MILES
While driving on the freeway at 55 mph, the motor stopped running. After coasting to a stop, the starter would turn over, but not start. The vehicle as been running very well up to this point.
Friday, August 27th, 2010 AT 2:08 PM
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Friday, August 27th, 2010 AT 5:54 PM
