1989 Ford Taurus CRANKS, CRANKS, BUT NO FUEL, FIRING?
SMALL1EAGLE
  • 1989 FORD TAURUS
  • 6 CYL
  • 2,468 MILES
HI, I'VE, GOT A PROBLEM, IN MY FUEL. I'VE, CHECKED-OUT, F/P-O.K./ CHECKED, OUT IGN. MODGLE, O.K./ GOT, SPARK!/ = LOOKING, AT THE "BOX"?= THE, BRAIN-BOX"? MY, IS ABOVE THE RADIATOR-SHROUD.I, CAN'T.(THINK). ANYTHING--ELSE, BUT THAT? IN, MY, (" HAYNES, REPAIR MANUAL", DOESN'T, COVER-ANYTHING, LIKE I'M, SEEING, LOOKING, AT IN THE ENGINE-COMP. GOT, TO BE, THAT, ( BLK.-BOX?). IT, WAS RUNNING-GOOD, THE DAY BEFORE? NEXT DAY I GO TO START IT-UP? CRANKS, BUT. NO, FIRING? THE, FUEL-PUMP COMES ON! I, CAN HEAR-IT, BUT, DOESN'T. START!I, PUT, IN A NEW FUEL-FILTER. CLEAN, S/P. DIST./ ROTOR, O.K. I'M, REALLY STUCK, ON ALL THIS?
Sunday, March 2nd, 2008 AT 1:42 PM
BMRFIXIT
  • 19,053 POSTS
Fuel pump coming on what if you don’t have fuel pressure e
______________check fuel pressure
check engine compression
check for injector pulse
check TPS volts
spray small amount of starting fluid in the throttle and crank check if it start then die
let me know
Sunday, March 2nd, 2008 AT 9:20 PM
