2001 Ford Taurus Engine Squeal
FREONDUDE
I recently bought my daughter a 2001 Ford Taurus with the 3.0L V6 Vulcan. Car history (which I got after purchase...bleh): was a new rental, later a "fleet" car, then I bought used.
Over the last few days, it has developed a constant squeal from the engine. Cold or hot, idle or reved abit, the squeal is there. Reving makes it a more pronounced squeal. Sound eminates from the passenger side of the engine in the vicinity of the serpentine belt and alternator. With engine idling, I sprayed a small amount of "Belt Conditioner" on both sides of the belt but it did not help. I do not see metal shavings around the pulleys of the Alternator, idler, crank, etc that have pulleys driven by the serpentine.
My guess is a failing bearing in the Alternator or Water Pump but praying it is not the Crank. Was going to loosen serpentine and hand turn the Alternator, Idler, and Water Pump pulleys to isolate source but hey I'm just a backyard mechanic. Advice?
Jan 11, 2007 at 7:22 AM
INDYUKE
  • 416 POSTS
Those are good ideas you have for tracking down the problem. Take a good look at the belt. There should be no cracks or any other defects on the inside or out. If you suspect you have a bad belt (they do go bad... sometimes develope a squeal because of a "glazed" inside) swap it out for a new one. Thoroughly clean all your pulleys and wheels before you put the new one in. Belit conditioner always seems to make belts squeal louder for me... not good. Denatured alchohol always seems to work good. Cleans like a solvent, leaves little or no residue and evaporates quickly.
Jan 11, 2007 at 2:51 PM
OSURLOSERS
I have a 2001 ZX2 (4 cylinder) which developed a similar squeal. It turned out to be the crankcase breather filter (it was clogged)...somehow the squeal seemed to come from the drive belt, so I replaced the drive belt and auto-tensioner...and the sound persisted. Anyways, I'm not sure if the Taurus has a similar filter. If it does, it's probably connected to both your air filter housing and the crankcase cover. The part cost $15. You can test my theory out by starting your car, wait for the squeal to start, pop your hood, and unscrew your oil cap. If the squeal stops, it's probably the crankcase breather filter. Good luck!
Mar 2, 2007 at 1:32 PM
Suggested Repair
Inspect the serpentine belt for cracks, glazing, or other defects and replace it if worn. Clean all pulleys with denatured alcohol before installing a new belt. Avoid belt conditioner, which can make the squeal worse.
Conversation Summary
The owner of a 2001 Ford Taurus 3.0L reports a constant engine squeal from the passenger side near the serpentine belt and alternator, present hot or cold and louder when revved. Belt conditioner did not help, and no metal shavings were seen. The expert advises checking the belt for cracks or a glazed surface, replacing it if defective, and cleaning the pulleys with denatured alcohol. Another owner of a different car suggested a clogged crankcase breather as a possible similar cause.
