1996 Ford Ranger Cold Start Stumble
TORQUEELBOW
Hello and thank you for your help,
I have a 1996 Ford Ranger 4-cylinder (2.4L?), 191,000 miles.
My truck has had problems on a cold startup. The engine tries to die out on me and idles roughly. When it's warm, it runs fine. There has been a tenacious check engine light since I bought the truck. I replaced MAF and the Cat. After going to two mechanic shops for expensive misdiagnoses, I finally went to the Ford Dealership for a diagnosis. The Dealership did an EEC test and the following codes came up: p1443, p1131, p1132. They told me the o2 sensor is stuck, the evap purge flow sensor needs replacing, and the intake system needs decarbonizing. They quoted me a ridiculous $750 for that and said they may find more problems when they're done. I looked and the purge flow sensor is a 5 minute job. What am I missing here? Is the decarbonizing a monster job? What scared them? If I do the decarbonizing myself. how involved is the process? I can do mech work but the price they quoted makes me worry about what I'm not seeing. I just need to pass inspection.
Your guidance greatly appreciated.
May 19, 2007 at 2:08 PM
SERVICE WRITER
  • 9,123 POSTS
2.5
I don't see the purge flow problem affecting the runnibility, just the evap system. It should stil be addressed.
Decarboning is not a monster project. The throttle plte should be cleaned for starters. Being a Ford, you have to be careful how you go about it as there is a special coating on the walls of the throttle bore. Remove the air snorkel to access the throttle bore.
https://www.2carpros.com/how_to/how_to_tune_up.htm
I would also remove the IAC motor and clean that.
For the intake valves, there are a couple of ways to do this. I prefer seafoam or castle products myself. The seafoam is more readily available to consumers. There is both a spray version and a container of it. The container works well, just follow the directions on the can. IF any questions, you can always post back.
May 20, 2007 at 12:19 AM
Suggested Repair
Clean the throttle bore carefully after removing the air snorkel, avoiding damage to the Ford throttle-bore coating, and clean the IAC motor. For intake-valve carbon, use Seafoam or a similar product and follow the can directions. Also address the EVAP purge flow sensor and stuck O2 sensor codes, though the purge issue is unlikely to cause the cold-run problem.
Conversation Summary
A 1996 Ford Ranger with high mileage stumbles and idles roughly on cold startup but runs fine when warm. Persistent codes P1443, P1131, and P1132 led a dealer to recommend an O2 sensor, EVAP purge flow sensor, and intake decarbonizing. The expert said the purge fault should be fixed but is unlikely to affect drivability, and that decarbonizing is straightforward: carefully clean the throttle bore and IAC, then treat intake valves with Seafoam or a similar product.
