2004 Ford Ranger stays running
KAE2001
  • 2004 FORD RANGER
  • 6 CYL
  • 4WD
  • 88,000 MILES
Start the truck, go to shut off but engine stays running even with the key off. Changed the ignition switch already. Have to pull the fuel pump fuse out to shut off.
Sunday, January 24th, 2010 AT 3:25 PM
DOCFIXIT
  • 18,828 POSTS
Hi Check PCM relay engine compartment maybe sticking and staying on.
Let me know
thnaks for donate
Monday, January 25th, 2010 AT 9:51 AM
KAE2001
I changed the relay and its doing the same thing as before.
Monday, January 25th, 2010 AT 11:33 AM
DOCFIXIT
  • 18,828 POSTS
Does relay have schematic? If yes check for voltage on terminal 86 key off
Monday, January 25th, 2010 AT 11:52 AM
KAE2001
10 volts
Monday, January 25th, 2010 AT 11:59 AM
DOCFIXIT
  • 18,828 POSTS
There should be NO voltage on that term key off that is what is pulling relay on and keeping it running. Is powered by fuse 10 which gets power from ignition switch. So problem with switch or connector. Was there any burnt terms on switch or connector? Wire is Light green/Violet
Monday, January 25th, 2010 AT 12:08 PM
KAE2001
I checked the connecter and wire, nothing looks burned or shorted there. It is actualy #9 fuse, pulled it and still had power to the green/violet wire. The "idiot" lights are on also when key is "off". Truck wont start until I disconnect the battery and reconnect. But still wont shut off.
Monday, January 25th, 2010 AT 12:52 PM
