2002 Ford Ranger low gas mileage
50,000 MILES • 6 CYL • 2WD • AUTOMATIC
VISION16
the ford dealership replaced my injectors and updated truck computer.The truck runs fine but I am getting on the average 7 miles per gallon less.what things would cause this?I need more information before i bring truck back to dealership.
Thanks
Jeff Sisco
honolulu96817@hotmail.com
Jan 12, 2008 at 11:34 AM
VISION16
the truck was still under warranty when i brought it in.It would run bad once in a while so I asked them to check it out.They said I had to replace the injectors.I went to another web site and they told me the following.
1)Check to see if battery was disconnected so the computer can adjust to new injectors.
2)Injector(s) might be leaking.I need to have feul pressure leakdown test down to see if I have leaky injestor(s).
what other things should I check for low gas mileage?
Jan 19, 2008 at 9:24 AM
VISION16
I havent had any modifications or work done on the the truck since the injectors installed.But its been more than 12 months.I had a company van I used most of the time and only drove the truck short distances on the weekends.I will talk to the dealer
and see what they say.
Thanks
Jan 19, 2008 at 5:40 PM
