2002 Ford Ranger Engine RPM
DRAGONPUFF
  • 2002 FORD RANGER
  • 6 CYL
  • 4WD
  • 86,000 MILES
After engine is warm, with defroster on, RPM drops about every 3-4 seconds, and sometimes stalls.
Wednesday, November 18th, 2009 AT 2:19 PM
  • 109,885 POSTS
The defroster runs the AC compressor to dehumidify the air coming into the car. So it is normal for you to notice when it cycles on and off. However, it shouldn't shut the engine off. Has the check engine light ever come on?
Wednesday, December 2nd, 2009 AT 8:23 AM
DRAGONPUFF
Yes, check engine light came on due to a crack in the pcv hose, I replaced the hose about 2 months ago and the light hasn't come back on. Do you think it might be the pcv valve?
Wednesday, December 2nd, 2009 AT 2:29 PM
