ok at first I thought it was the clutch going out but now i wonder if it's the tranny.. in neutral everything is fine when i push in the clutch you can faintly hear a rattle sound when I put it in reverse no change when i start to release the clutch petal and start backing up I can hear a loud rattle.. go into first it goes in fine drive off just fine in all forward gears its fine when petal is released now slowing down 4 too 3 everything goes ok 3 too 2 same but now 2 too 1 just as it goes into 1st with petal pressed in still it makes a quick growl like baarr- rrwwwhh (ha ha) but now tonight everything is the same except when I went to take off from a stop going forward as I was releasing the clutch petal I could feel it as if it was grabbing then slip then grab then slip just a bit where the truck was barely jumping over and over until the petal was fully released then it went on as normal... but a few weeks ago I couldn't even get it into any gear with it running in neutral then it got a little better where it would go in most of the time like it was yesterday.. is it the clutch or is it the tranny??? so very confused...
Mar 26, 2010 at 10:39 PM
