2002 Ford Ranger
JEROMEPETZ
  • 2002 FORD RANGER
  • 6 CYL
  • 100,117 MILES
My Rangers lights get brighter for a split second and dim down to normal, I notice the battery light flicker and the battery gage spick for a split second. It only dose this maybe 3 times when I drive it. Hope you cane help. Thanks
Tuesday, May 4th, 2010 AT 10:17 PM
  • 110,055 POSTS
IT sounds like the voltage regulator is going bad. In this case, it sounds like it is letting it overcharge for a split second. That is not good. If it was to continue doing that, it could burn things up. What I recommend is having the alt checked. The reagulator is an integral part of the alt. Most parts stores will do it for free.
Let me know what you find.
Tuesday, May 11th, 2010 AT 12:50 PM
