2000 Ford Ranger O2 sensor
KIRTGREEN
  • 2000 FORD RANGER
  • 6 CYL
  • 17,000 MILES
Have a trouble reading bad O2 sensor and O2 sensor heater. Went to look under truck and the sensor behind the catylitic converter have cut wires! I can't tell where they went to. The Check engine light has been on since I bought it and just recently started driving. Where should these missing wires lead to? Thanks
Thursday, April 9th, 2009 AT 3:32 PM
OBXAUTOMEDIC
  • 3,711 POSTS
If you cannot find other cut wires somewhere near then it is possible that it has been disconnected at the connection. Which could be a foot or more away from the cut wires. Take a look at the other O2 sensor connection then look under the vehicle and see if you can find that connection. Also might be easier since you should replace that sensor to get the new one and install it then stretch the wire out to find the area were the connection should be. Post finding.
Thursday, April 9th, 2009 AT 3:41 PM
KIRTGREEN
Ok, Thanks for your speedy reply. I did find a plug not too far away from the wire-cut sensor but it had 4 wires and my sensor has only 3. There appears to be no extra wires whatsoever at the other 2 sensors. The spit there is neat and clean.
Thursday, April 9th, 2009 AT 3:45 PM
OBXAUTOMEDIC
  • 3,711 POSTS
That's ok it only indicates that the sensor is not heated. That is what the 4th wire would be for.
Thursday, April 9th, 2009 AT 4:00 PM
KIRTGREEN
Thanks so much. So that must be the plug I need to go to. As long as a new sensor has a wire about a foot long. Thanks so much for your speedy help. I tried to give you feedback but only have.1 points and it wouldn't let me do it. Thanks a lot!
Thursday, April 9th, 2009 AT 4:08 PM
