2000 Ford Ranger Engine Shudders
60,000 MILES • 4 CYL • 2WD • AUTOMATIC
WHEELCHAIRDUDE49
  • 73 POSTS
Engine shudders when coming to a stop. Smooths out.
This happens Once in a while. I just fixed a P0171
code which turned out to be a hole in the Egr tube.
That tube was leaking for about 2 months.
these are the things i changed before the tube.
Plugs
Wires
Maf sensor
fuel filter
Pcv and 2 vacuum hoses
Fuel pump was tested and is ok.
Should i change the IAC valve to cure the shudder?
Oct 19, 2010 at 1:52 PM
  • 110,246 POSTS
Have you checked it? If you need directions, check this posting. I have been dealing with a similar issue and have outlined the procedure for checking the IAC.
Just so you know, the IAC will cause a looping idle. Is that what is happening? Its purpose is to allow air into the intake when the throttle plate closes to prevent the engine from stalling.
Apr 16, 2019 at 4:57 AM
WHEELCHAIRDUDE49
  • 73 POSTS
No it isn't looping shudder. Happens just before i put it in reverse to park but never when I'm going down the road and when i come up to a light . It shudders and then smooths out.
  • 110,246 POSTS
Has the check engine light ever come on? Have you checked fuel pump pressure? Have you checked for vacuum leaks?
WHEELCHAIRDUDE49
  • 73 POSTS
Fuel pump 60 psi koeo Engine running 65psi
leak down is 60 psi after 5 minutes. Had the vac system smoked thats how i found out the EGR tube had a hole in it. I replaced that yesterday. I did have a code of P0171 before i fixed the EGR tube. No code since
  • 110,246 POSTS
Have you checked the IAC?
WHEELCHAIRDUDE49
  • 73 POSTS
Not yet but hope to this weekend . I will let you know what i find out.
  • 110,246 POSTS
WHEELCHAIRDUDE49
  • 73 POSTS
I removed the wires to the IAC valve, rpms dropped to 500 but didn't stall . couldn't reach the pins on the valve
to test it with a multimeter. I did notice that it seems to be getting worse and now it's shuddering when i turn corners. Could this be a powering steering pump or serpentine belt issue?
  • 110,246 POSTS
I wouldn't think the belt or PS. Is there any smoke from the exhaust?
WHEELCHAIRDUDE49
  • 73 POSTS
no smoke
WHEELCHAIRDUDE49
  • 73 POSTS
I'm thinking it is the power steering or belt. Noticed tonight that it shuttered , vibrated,when i turned the steering wheel. Same thing i'm experiencing when coming to a stop. Belt tentioner?
  • 110,246 POSTS
anything is possible. If the PS pump is bad, it could be placing more of a load on the engine, but that doesn't sound right to me. A tensionier wouldn't do it either. Remove the belt and see if the problem is gone. NOTE: Only run the engine for a few seconds to see if the problem is gone. It will overheat. While it is off, spin the accessory pulleys to see if they feel free and not an issue.
