1999 Ford Ranger trans not shifting all the time
RDK
  • 1999 FORD RANGER
  • 4 CYL
  • 66,505 MILES
Yesterday I started driving and the car. Would not shift out of ist gear. I came home and used another car.A little later my dad took it out and it did the same but them stared working fine. Also when its not shifting right the speedometer is not working.I changed the filter and fluid but that didnt help sometimes it works fine then while your driving along itdoes the same also when it acted up the overdrive light starts blinking. Can use some help thanks
Monday, September 1st, 2008 AT 1:41 PM
MERLIN2021
  • 17,250 POSTS
There is a tech bulliten on your truck.
4R44E/5455E - SLIPPING SHIFT/DELAYED OR NO ENGAGEMEN -1999 Ford Ranger
Page 1 of 3
TECHNICAL SERVICE BULLETIN
Reference Number(s): 99-16-10, Â Date of Issue: Â August 9, 1999 Related Ref Number(s): 99-16-10
ARTICLE BEGINNING
CONDITION
TRANSMISSION - 4R44E OR 5R55E - SLIPPING SHIFT/DELAYED OR NO
Monday, September 1st, 2008 AT 4:52 PM
RDK
You missed this one it was the abs sensor. It is located on the differential
Wednesday, September 3rd, 2008 AT 3:44 PM
MERLIN2021
  • 17,250 POSTS
You did not mention an ABS light on. You mentioned tyranny troubles, and this TSB applies to your truck.
Thursday, September 4th, 2008 AT 4:50 PM
