HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Brakes
Wheel Cylinder
Replace/Remove
SPONSORED LINKS
1999 Ford Ranger
STUFFEDKITTY29
MEMBER
1999 FORD RANGER
1999 Ford Ranger 6 cyl Two Wheel Drive Automatic
how do u remove the corner lights from a 99 ford ranger? I am replacing them with clear outs.
Thursday, May 13th, 2010 AT 10:52 PM
MECHANIC
Are you refering the orange lights on this truck?
SPONSORED LINKS
Tuesday, May 18th, 2010 AT 10:45 AM
STUFFEDKITTY29
MEMBER
1 POST
Yes. The turn signals and the top corner light. I think they come out as one unit, but I am not sure.
Tuesday, May 18th, 2010 AT 11:14 AM
MECHANIC
They do. I believe the bolts are accessable from under the hood. THe headlight lens is a seperate assembly, but I think you need to remove it first.
Tuesday, May 18th, 2010 AT 11:19 AM
Please
login
or
register
to post a reply.
Related Wheel Cylinder Replace/Remove Content
1999 Ford Ranger Brakes Give Out When Completing A...
When Coming To A Complete Stop My Brakes Give Out And It Is Very Hard To Push The Brake Pedal. I Have Changed All Of The Brake Pads And...
Asked by
rickypeters
1999
FORD RANGER
Brake Pedal Seems To Be Connected To The Clutch Pedal
The Brake Pedal Seems To Be Connected To The Clutch Pedal. They Both Slightly Move Forward And Back Simultaneously. When Depressing The...
Asked by
flyingpork
1 ANSWER
3 IMAGES
1999
FORD RANGER
I Need A Diagram Of The Rear Brake
I Need A Diagram Of The Rear Brake Drum Fully Assemble And A Diagram Of Fully Disassemble
Asked by
trafalski2
1 ANSWER
1999
FORD RANGER
1998 Ford Ranger Shaking In Steering Wheel And Brake...
My Brakes Has Always Been Good. Good Stopping Power, No Noise, And Smooth Stopping. But Recently I Started To Hear A High Pitched Noise...
Asked by
driver2009
1998
FORD RANGER
1996 Ford Ranger Brake Lines
Working On This Truck I Found Someone Who Has Ridged The Brake Lines From The Master. I Need To Know Where The Two Lines From The Master Go...
Asked by
carfixerleo
1 ANSWER
1996
FORD RANGER
VIEW MORE
SPONSORED LINKS
Brake Shoe and Drum Replacement
Bleed your ABS Brake System Correctly Video
How to Bleed and Flush Your Vehicle Brakes
Online car repair manuals
