1998 Ford Ranger Location of block heater
1998 FORD RANGER
11,200 MILES • 6 CYL • 4WD • MANUAL
JOEL HARDY
I have a 98 Ranger with a 3.0L engine. I have not been able to determine whether or not it has a block heater. Can you tell me where to look on the block. Also, depending on the weather the cab heater only adjusts to full-hot (winter) or full-cold (summer) there are no median tempuratures.
Dec 19, 2008 at 12:16 PM
BLACKOP555
  • 10,386 POSTS
would be in a engine block freeze plug hole, passanger side of engine, or on the lower radiator hose dependent on the kind you have.
look for a 110v standard electrical cord hanging under the vehicle to see if you have one or not.
Dec 24, 2008 at 12:44 PM
