Why does my hi lo light flash off and on when not in use? Only does this about once a week
Tuesday, January 26th, 2010 AT 3:27 PM
MECHANIC
THere could be a bad connection where the wiring harness connects to the 4wd actuator on the transfer case. Remove it and make sure there is no corrosion and it is tight.
Let me know wha tyou find.
NOTE: WHen it is flashing, chances are the 4wd won't work.
