1997 Ford Ranger transmissions slip
REESECHAD
  • 1997 FORD RANGER
  • 6 CYL
  • 4WD
  • 104,000 MILES
1997 ranger the transmission was slipping and was low on fluid a few weeks ago, added fluid and everything was fine for about a month and now the trans slipped again when pulling a hill and even came to where it wouldnt pull it at all. The fluid level is fine after letting the truck sit for about a minute the truck went in gear and was fine for awhile and them did the same exact thing. Can you tell me what the problem may be?
Monday, September 15th, 2008 AT 5:50 PM
  • 31,937 POSTS
HI there,
this can be an oil pressure servo problem of a faulty clutch pack, I would get to a transmission specialist to get a test and report, if you keep driving while it is slipping you will be do more damage to the transmission.
Mark (mhpautos)
Monday, September 15th, 2008 AT 6:20 PM
REESECHAD
It has only done it twice on me but it only has done it on a steep hill. I am not much of a machanic but thanks for you info.
Monday, September 15th, 2008 AT 6:25 PM
