1997 Ford Ranger Jarring Bump when starting off or stopping
1997 FORD RANGER
74,000 MILES • 6 CYL • 4WD • AUTOMATIC
DOS2
Experiencing a definate jarring bump when taking off from a dead stop. Also the same bump occurs when coming to a complete stop, just at the last moment.
The transmission seems to operate fine as far as shifting in all regards with maybe this exception, if it is actually a transmission issue?
It is in 2 wheel drive during this event, driving on city streets. I haven't tested it in 4 wheel drive. If I really baby the accelerator when moving from a stop I can sometimes avoid the event.
The transmission fluid has been checked and is OK. The overdrive function seems to work OK.
There is a vibration that is distinct that occurs at 55 mph and above that I'm not sure is related.
Jun 23, 2010 at 5:31 PM
  • 31,937 POSTS
hi there, i would be getting the transmission line pressures checked as this sounds like a pressure related harsh gear change, as for the vibration, start looking at tyres first.
mark (mhpautos)
Jun 23, 2010 at 5:37 PM
