My transfer case went from sometimes to never changing into 4 wheel drive. The resistance checks for the feedback from the motor are OK(at the motor). If I apply 12v to the motor, it moves smoothly. The relays click. The 4hi and 4lo lights blink 6 times every few minutes. I took out the small relay and applied 12v and checked the resistance and it was good. Is there more than one relay between GEM and motor? I swapped in a used GEM and the 4x4 high light came on for a while (but didn't change transfer case), then did the same blinking routine as the other one. Can anyone tell me what 6 blinks means or offer other advice? I read the post for the 95, they sound a little different. What do the moving papers in front of the questions mean?
Dec 29, 2009 at 6:10 PM
