1996 Ford Ranger Starter
186,000 MILES • 4 CYL • 2WD • MANUAL
PUNKINGINDRUBLIC
My truck recently wouldn't start with a clicking sound when I turn the ignition. It will start when a screwdriver is placed on two bolts of what I believe is the starter. I was told this will only work about 50 times until I need to get it replaced. From apperance the part I'm placing the screwdriver onto (I assume the Solenoid((SP?))) is what needs replaced. I looked on advanced auto parts and searched compatible parts and looked like the smaller piece of the starter cost about 20 bucks and the entire thing is 100 or so.
My main question is, the fact I can start my truck with a screwdriver, means the starter is fine correct? Just the solenoid which from what I understand regulates voltage needs replaced.
Thanks for any help. This is my first thought into repairing my own vehicle, I usually rush it to a shop but when moneys tight moneys tight.
Oct 6, 2010 at 12:46 AM
WRENCHTECH
  • 20,760 POSTS
If you are able to start the car by jumping the terminals at the start, then it's not likely the problem is in the starter at all. It's going to be somewhere else in the starter circuit and will have to be troubleshooted when the problem is present.
Oct 6, 2010 at 12:59 AM
