HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Not Cranking Over
Will not crank over
DAVIDTHIEKE
MEMBER
1996 FORD RANGER
Electrical problem
1996 Ford Ranger 4 cyl Two Wheel Drive Manual
all I hear is clicking when trying to start truck, already replaced starter, and the solenoid on the fender, any ideas?
Friday, June 25th, 2010 AT 12:25 PM
BLUELIGHTNIN6
MECHANIC
Make sure charging system is tested good and ensure battery cables are tight and ends are clean
Friday, June 25th, 2010 AT 12:29 PM
GET123GOT
MEMBER
Check ground wire
Friday, December 3rd, 2010 AT 6:16 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
96 Ford Ranger 2wd 4.0 Starter Won't Engage, Just...
Drove To Gas Station. Got Gas. Tried To Start And Starter Doesn't Engage. Only Spins. Installed Starter From Junkyard. Same Result....
Asked by
lewkit
1996
FORD RANGER
VIDEO
Car Not Cranking? Try This | EASY
Instructional repair video
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
Engine Not Cranking Over?
The Engine Will Not Turnover It Just Clicks When I Turn The Key. Battery Is Good And Charged So I Really Don't Know What Might Cause...
Asked by
Benjamin1119
2 IMAGES
1993
FORD RANGER
1994 Ford Ranger Wil Not Crank
I Brought A Re Man Pm For Advance Auto Bwd The Truck Will Not Crank It Try To Sometimes But Don't. I Was Told By Advance That It Do Not Have...
Asked by
dill-11
1 IMAGE
1994
FORD RANGER
1993 Ford Ranger Wont Crank Over
Hi. For The Past 2 Months I Have A Bit Of A Mystery With My Ford Ranger. It Will Not Crank Over Sometimes. I Have Replaced The Following...
Asked by
steharris
1993
FORD RANGER
No Crank No Start
I Was Testing The Tps When I Touched The Hot Wire It Grounded Out Or Something. Now Car Wont Crank. Starter, Battery, Ignition, Clutch...
Asked by
Tank1182
2002
FORD RANGER
VIEW MORE
Battery Replacement Dodge
Battery Replacement
