1994 Ford Ranger valves
YMMOT
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 273,000 MILES
What kind of valves are on my truck?
Wednesday, May 26th, 2010 AT 12:52 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Not quite sure what you are asking.
There are the Exhaust Valves and the Intake Valves
Wednesday, May 26th, 2010 AT 1:05 PM
YMMOT
Yes but are they adjustable, see the problem is I dont have good compression in 1 and 3 so either its the valves or the rings
Wednesday, May 26th, 2010 AT 11:21 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry for delay.
Ok, well here is how you can detemine if it is the rings or not.
Pull the plugs on those 2 cylinders and squirt some engine oil into them then check compression if compression increases then it is most likely the rings.
If compression doesn't increase then could be the valves. If it is the valves it could just be weak valve springs or bent valves.
Saturday, May 29th, 2010 AT 4:34 PM
Related General Content
