1994 Ford Ranger slave cylinder
BREWER01
  • 1994 FORD RANGER
  • 4 CYL
  • MANUAL
  • 200,000 MILES
Where is it located and how do I replace it
Tuesday, December 4th, 2007 AT 6:47 PM
FSTRANGER302
  • 117 POSTS
Hello, the slave cylinder is located inside of trans. You would have to remove the trans from the engine. Then remove the slave cylinder from the trans. There is a special clip on line to slave clinder. Push in to remove the line. Make sure you bleed all air from the slave cylindeer hope it helps please let me know thanks pat
Wednesday, December 5th, 2007 AT 11:19 AM
Related General Content
