If the evr is bad, it wouldn't make your car struggle for 20 mph, but would probably contribute to a pinging problem since it may not supply enough vacuum to pull the egr open enough, they are a known part prone to failure. 170 psi is a healthy number, your engine is healthy given all are the same, that's good. It's funny, trying to find the compression psi is hard, most books just give you the high and low numbers.
Sunday, December 31st, 2006 AT 4:59 PM
