1992 Ford Ranger TIMING
BJNMGN
  • 1992 FORD RANGER
  • 4 CYL
  • MANUAL
  • 98,000 MILES
There is a miss when cranked up at idle and there is
oil in the air filter also need to know what timing should be set at
Tuesday, January 22nd, 2008 AT 11:53 AM
2CARPRO JACK
  • 11,533 POSTS
Oil might be due to a cylinder that has a bad valve or other problem. Start with compression test to be sure the engine is worth setting the timing on.
Wednesday, January 23rd, 2008 AT 7:51 AM
