1991 Ford Ranger oil pump
RANGERDANGER17
  • 1991 FORD RANGER
  • 4 CYL
  • MANUAL
  • 199 MILES
Can someone please tell how hard it is to change an oil pump if I need any specail toolsor knowlegde
Monday, May 19th, 2008 AT 8:08 PM
BMRFIXIT
  • 19,053 POSTS
Remove oil pan.
Disconnect pick up tube from main bearing cap stud
remove oil pump attaching bolts
remove oil pump assembly with drive shaft
Monday, May 19th, 2008 AT 9:04 PM
RANGERDANGER17
  • 224 POSTS
Okay thank you do u know anything about my other question
under 1991 ford ranger engine noise
Monday, May 19th, 2008 AT 9:29 PM
BMRFIXIT
  • 19,053 POSTS
Sorry what question
and what noise
Monday, May 19th, 2008 AT 9:34 PM
RANGERDANGER17
  • 224 POSTS
This question I posted earlier
i was driving truck when I down shifted to second my engine started too make a this noise
it is internal noise clicking noise that picks up with the rpm and drops to idle when the clutch is in
the clicking stays with the engine it sounds like a rocker spring broke or came off
but I was also told that it can make that noise if the oil pump goes bad
but my oil preussure gauge is either broke or there is no oil pressure can some one tell my if I can still drive my truck like this or if the engine is shot
if u have any info on this please help
Monday, May 19th, 2008 AT 9:38 PM
BMRFIXIT
  • 19,053 POSTS
You need to check and make sure you have an oil pressure
you should not drive with no oil pressure or engine will be damaged
locate oil pressure switch and check if its any good
u can also remove it and check oil pressure throw it by hooking up a gauge and starting the engine
as for the noise
u may remove valve cover and check the rocker arms if u have collapse lifter or other issues
but oil pressure is the top issue no sense doing any thing without oil pressure
and if you have a lot of miles it maybe wise to get another good used engine
good luck
Tuesday, May 20th, 2008 AT 5:42 AM
RANGERDANGER17
  • 224 POSTS
Okay thank you a lot
Tuesday, May 20th, 2008 AT 6:05 AM
RANGERDANGER17
  • 224 POSTS
Okay thank you a lot[/quote:e52ea3fb31]
okay I got a new pump and a new pressure switch and gaskets for the oil pan and I the oil pan off
but I wont come it has bars and suspesion arms keeping it from falling to the ground the transmisson is too close to slide it that way and the suspesion arms keep it from going forward and there is something inside keeping it from moving sideways
the front suspenion arms are tied in on the same bracketas the engine mount
my question is how do u remove the oil pan
so that I can replace the oil pump
Tuesday, May 20th, 2008 AT 2:14 PM
RANGERDANGER17
  • 224 POSTS
Okay thank you a lot[/quote:45423a9c17]
so that I can replace the oil pump[/quote:45423a9c17]
I got it but thanks alot
Tuesday, May 20th, 2008 AT 4:09 PM
