1986 Ford Ranger starter
JD MCKENZIE
  • 1986 FORD RANGER
  • 6 CYL
  • 4WD
  • MANUAL
  • 135,000 MILES
Starter not operating-bench tests OK - replaced
fender mounted solenoid - cleaned cable
connections(grounds) - new battery with clean
tight terminals
Friday, February 5th, 2010 AT 9:54 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Hi JD,
Check for power at the Small Wire Marked with an "I" on the Relay Solenoid you replaced, while someone tries starting. If no power check Ignition Switch.
Friday, February 5th, 2010 AT 10:15 PM
