1995 Ford Probe Clutch Pedal to Floor
GLASSMAN
My cluch pedal went all the way to the floor and im not sure exactally which part has failed. The cluch master cylinder or the slave cylinder. My cluch cylinder feeds off the master brake cylinder and i tried bleeding the line at the cluch cylinder but get no fluid or air. i noticed when i had to drive it home i could push the cluch pedal real fast and it would allow me to change gears, but other than that it would just stay on the floor. can you tell me what you think it might be. This has been a great car for the past 11 years and has 140,000 miles. thanks
Mar 13, 2006 at 11:52 AM
RAYHUT
  • 134 POSTS
if it was me i would replace both.
Mar 13, 2006 at 9:33 PM
Suggested Repair
Replace both the clutch master cylinder and the slave cylinder.
Conversation Summary
The owner of a 1995 Ford Probe 2.0 reported the clutch pedal dropping to the floor. Bleeding at the clutch cylinder produced no fluid or air, though a very quick pedal press sometimes allowed a gear change. The expert recommended replacing both the clutch master cylinder and the slave cylinder.
