1995 Ford Probe Keyless Entry Module
1995 FORD PROBE
DUCKGOOSE1
Electrical problem
1995 Ford Probe 4 cyl Automatic 135000 miles
This is related to a previous question I asked... I do have a bad keyless entry module on the car, the dealer said it would be at least $500 to replace. I'm sure that's almost as much as the car is worth at this point, but it seems that it is draining the battery constantly as it continually tries to lock and unlock the doors when not in use. Is there a way to just unhook it myself to stop these problems?? I was present when they were inspecting at dealership, and I am aware where the module is located and how to get to it. If this can be done, how?
Thanks a mil!
May 11, 2009 at 2:18 PM
BMRFIXIT
  • 19,053 POSTS
Try and unplug power door relay located at top right kick panel
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 11, 2009 at 9:16 PM
