1994 Ford Probe idol
1994 FORD PROBE
179,371 MILES • 4 CYL • FWD • MANUAL
DOUGPROBE
my car idols at 3000 to 4000 rpm and the check engine light randomly comes on and off and since its a 94 aperantly it does not save the code, and when u turn the car off and back on the light is off so when a shop trys to scan it nothing comes up. can u help me?
Mar 29, 2009 at 9:04 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:4368489d35="dougprobe"]Engine Performance problem
1994 Ford Probe 4 cyl Front Wheel Drive Manual 179371 miles
my car idols at 3000 to 4000 rpm and the check engine light randomly comes on and off and since its a 94 aperantly it does not save the code, and when u turn the car off and back on the light is off so when a shop trys to scan it nothing comes up. can u help me?[/quote:4368489d35]
Check for Vacuum Leaks it is a common cause of high idle. Also check the IAC (Idle Air Control Valve)
Mar 29, 2009 at 9:08 AM
