1994 Ford Probe Engine stalls fuel cutout light
MATT19028
  • 1994 FORD PROBE
  • 4 CYL
  • FWD
  • 115,000 MILES
My engine start cold and run fine for a bit but when it warms up it stalls at idle and the fuel cut out light is on as well as the check engine light. I checked the spot where the switch is and there nothing there.
Tuesday, September 8th, 2009 AT 1:46 PM
CEL being on is an indication of a problem within the engine management, scan the computer for code/s this is your starting point finding out what's going on.
Tuesday, September 8th, 2009 AT 5:10 PM
MATT19028
I figured that but I just got the car the other day so im gonna get all my basic maintance things and I have to replace the muffler resonator. If the problem persists ill check the codes. I was just curious b/c I went to the manual swich to turn on the pump but theres no switch. There a sticker that says fuel pump shut off but then theres just a hole where its supposed to be any ideas?
Tuesday, September 8th, 2009 AT 9:04 PM
