1994 Ford Probe
LARJEN
  • 1994 FORD PROBE
1994 Ford Probe 4 cyl
how do I change a water pump on a 194 ford probe
Tuesday, January 19th, 2010 AT 2:41 PM
1. Disconnect battery ground cable, then isolate cable end with electrical tape.
2. Drain cooling system.
3. Remove power steering pump belt shield, then loosen adjusting bolt.
4. Loosen lock bolt and power steering pump through bolt, then remove power steering belt.
5. Loosen alternator adjusting bolt, then loosen alternator upper mounting bolt and remove alternator belt.
6. Remove cylinder head cover.
7. Raise and support vehicle.
8. Using water pump pulley tool T92C-6312-AH or equivalent, remove water pump pulley.
9. Remove splash shields, then the timing belt.
10. Remove five water pump attaching bolts, then the water pump.
11. Reverse procedure to install. Tighten water pump to 14-19 ft lb. Tighten water pump pulley to 6-7 ft lb.
Tuesday, January 19th, 2010 AT 3:16 PM
LARJEN
Thank you very much for answering my question so fast.
Tuesday, January 19th, 2010 AT 6:10 PM
